Hi All
I am currently doing a bathroom and customer wants a humidistat fan fitted, I have limited access to the ceiling due to a ensuite above so I cant tap into light circuit. There is a redundant shower circuit(10mm) feeding an isolator outside the bathroom and then into the room, I want to extend this circuit to the small crawl space above and fit the fan on this . Do I need to fit an FCU before the fan and what rating mcb should I use at the D,B. The circuit is rcd protected. Hope this all makes sense.
