Humidistat Fans | on ElectriciansForums
Guest viewing is limited
Discuss Humidistat Fans in the Australia area at ElectriciansForums.net
N
ngoodson1969
Hi,
Does a humidistat fan need a Switched Live, it seems that it doesn't need to go ON with the light but just whenever the sensor says so. In that case does it just need a Permy Live and Neutral?
Cheers
Nick
Be carefull there is more than one type on the market. Some work fine as Sintra said. But others need a switched live to activate, then they time out and stop if the humidity levels are low enough. If not, they continue to run until the humidity as dropped, and then go off. These usually have adjustments for time and humidity settings.
Reply to Humidistat Fans in the Australia area at ElectriciansForums.net
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
I have posted this years ago, it is the way I wire fans which gives the fusing required by a lot of manufacturers and the isolation required...
Recommended Sponsor News
Hi everyone,
