HV Schneider Breaker | on ElectriciansForums
Discuss HV Schneider Breaker in the UK Electrical Forum area at ElectriciansForums.net
gloucetser
Hi all,
We have a HV Schneider GenieEvo breaker, on the name plate, this device is rated for 50Hz. What would happen if we used a 60Hz supply? Can the 50Hz breaker be able to take 60Hz.
thanks
Since they are VCBs the breaking capacity should be similar/identical between 50 and 60hz, however the overall switchgear will contain CTs and possibly VTs , these are likely to be specific to a particular frequency.
Hi all,
thanks
pretty sure from memory they are indeed designed to work on both frequency's, Best check with Schneider but I think they will work on 60 HZ
Reply to HV Schneider Breaker in the UK Electrical Forum area at ElectriciansForums.net
Given the apparent lack of earth, combined with no short circuit or over current protection, I'd contend that luck has been the sole factor...
nicebutdim
N
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
