i am going in for my am2 in jan but i want to get a head on what i am doing but i want to see what the question on the exam are like and what to no if anyone knows any website i can go on to practice them please help thank you
The online exam is borderline ridiculous..............its 45 (i think) questions that are multiple choice, 4 possibilities......sounds easy right? ...........
It gets easier..................
You're aloud the OSG, BS7671 and GN3 in the exam with you, every answer you'll need is in them.....my advice is just familiarise yourselfs with these books, make sure you know where to find everything and aslong as you read the question a few times before answering so you fully understand it you'll be fine.
The install, correct as above their is no containment, ridiculous. Although, the time allowed which i think is 8hours or something? Does fly by, so make sure you get you're head down and work at a constant steady pace. I know a guy that failed because he'd not tightened his SWA gland up tight and it was undone by the assessor's hand....everything else was done perfectly, so make sure you've got your brain engaged throughtout as you don't want to be resitting for something as careless as that.
Fault finding not too difficult either really, just you're bog standard faults....L-N cross connections at sockets, breaks in the bonding, polarity ect... think they have 2 faults on a heating system though now, so if you're gonna get any practice it might be in how to diagnose faults on heating systems....it's simple enough but if you've never worked with a heating system then you might over complicate yourself.
Best of luck buddy.
