i am really needing help about 3 phase with 4 wires | on ElectriciansForums
Discuss i am really needing help about 3 phase with 4 wires in the Electrician Talk | All Countries area at ElectriciansForums.net
stewart1980
hi there i am starting my own company and i have just bought a new tyre machine my unit has single phase but the machine is 3 phase with 4 wires black blue brown yellow and green on the side of motor it has v-220/380 now can i use this in my unit and if so how do i go by doing it please help as losing money now with it not working
You'll probably end up either replacing the motor with a single phase equivalent or upgrading the electrical supply in your unit to 3-phase.
Can you attach a snap shot of the motor? If not what is the kilowatt rating and rpm? Maybe a make and model number.
Or possibly you might be able to use a Single > 3Phase converter box, but that'll depend a bit on the device and how chunky the motor is for the cost... As others have said, a single phase motor may be an easier conversion.
a single phase motor should cost you around £100ish, max. then you'll need somebody to get the right one and fit it. probably another £100ish.
would this do it IMO Jaguar VXS Single to 3 Phase Inverter 0.75KW
Single phase to 3 phase inverter 0.75KW
Removed from working control panel
Comes mounted on heatsink with built in line filter
If you go the inverter route I would suggest oversizing it to acommodate the start current and the fact it's an AC3 load with less than idea power factor.
Reply to i am really needing help about 3 phase with 4 wires in the Electrician Talk | All Countries area at ElectriciansForums.net
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
I have sent you my contact details where in the West Midlands are you? I am based north of coventry but travel the county and beyond you may...
Swap the blue and black wires over this will reverse the moter
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
This UK company seem to sell parts for them so it might be worth contacting them after that you could try the manufacturers La Rocca | Máquinas de...
