i boost connection | on ElectriciansForums
Discuss i boost connection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A
ambrad
Hi All
i have been asked to fit an i boost to an existing system that has solar panels. Its the first i have fitted so i am trying to get all the info before i fit. The instructions are fairly straight forward but the in structions/wiring diagram finish at he final instruction stating, to immersion heater via isolator and thermostat. This may seem straight forward but does this mean i have to wire it through the existing cylinder stat and then to the element or fit a seperate new cylinder stat.
If anyone has fit one any help or diagrams would be good.
thank you.
The Immersion heater should already have a stat on it / built in to it.
We don;t supply or intall the iBoost iunits, however I would be suprised if it was any more complicated than installing it in the supply line to the immersion heater (make sure there is a double pole isolating switch between the iboost and the immersion)
Reply to i boost connection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
