I had more chance of winning the lottery | on ElectriciansForums
Discuss I had more chance of winning the lottery in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Heywood Lancs
We fitted a solar edge system back in March in Scotland
Anyway the customer called me to report a fault on a panel on his system ,
so I checked his system on via the solar egde portal online and yes one of his panels where down
so I traveled 4 hours to replace the power optimizer behined the panel
I replaced it and hey presto it worked fine.
I looked at the faulty power box and could not for the life of me see anything wrong with it.
so a few days passed , I got bored and decided to looki inside the power optimizers
so I unscrewed the lid and looked inside I noticed little black spots inside on the chip board So i looked closer and the black dots where moving
little bugs or flys where running around inside the power optimizer
what are the chances of that a fle must of blew the chip board or somthing as it did not work.
I had some faults to find before but this one must be at the top.
so 8 hours drive all for some little bugs , how they got inside I will never know.
one to tell the grand kids.
I had this years ago near the coast of the North sea. I fitted Stienel Pir's around a building, I paid the extra money for them because of their reputation and because they were to be fitted about two hundred yards from the sea. After six months I got the call that one was not working, so when I get the cover off it is infested with tiny bugs/flies. Now I made sure this was sealed super tight as the winds are ferocious and the spray from the sea reached them. I will never understand how they got in there, unless I left them open on the ground and the little fella's got in and bred like crazy.
its like little mites, they get attracted to the warm circuitry, and also they seem to like the type of oil that gets sprayed onto finished circuit boards as a protectant (to stop IC pins from corroding) in the factory, as the old laquer they used to spray on (like clear varnish) got phased out due to chemical nasties....
you can get these going into your mobile phone as well if you keep it in the car or van and they end up running around on your screen which is not nice.......can I borrow your phone.....Sure.....EEEEEEKKK BEESTIES!!!!
Reply to I had more chance of winning the lottery in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
