Trying to figure out how to properly wire an MR16 LED fixture to light given that I only have 2 accessible wires and these are both hot when the switch is enabled (using voltage detector). No neutral is available here and it's part of a series -- 3 other existing lights function when the switch is turned on, as you can see in the second shot.
I have some MR16 ceramic base adapters but I'm hesitant to connect one here given the situation. Any thoughts are much appreciated!
