I know this happens but this is the first time I've seen it | on ElectriciansForums
Discuss I know this happens but this is the first time I've seen it in the UK Electrical Forum area at ElectriciansForums.net
Lip.82
Middlesbrough
I came across this today. Does anyone know how long it takes to totally destroy a cable?
[ElectriciansForums.net] I know this happens but this is the first time I've seen it
I think the "wet" part you are showing is from the insulation tape. The age and make up of the cable will be a factor as older cables contained plastisizer to make the sheath more flexible and it is this which causes migration.
I’ve seen polystyrene nibble into a pvc sheath a bit, but never had a fault as a result.
Polystyrene is a decent insulator so, as above, all should be ok if not disturbed.
I remember going to an aquatics shop years ago that was having tripping problems, I assumed it was an rcd that was tripping but when I got there and they showed me it was an mcb. After having a look round I soon found the issue, the tanks were insulated with polystyrene and the wire was run on it but now was in the poly with no sheath or insulation! The wire had gone through it like a cheese wire and all 3 conductors were perfectly separate from each other until a tank they had been emptying where the 3 had shorted and left a massive black scorch mark and melted a huge crater! Ender up having to totally rewire the whole tank lighting properly. Must of taken out about 200m of ready to tat in copper out!!
Reply to I know this happens but this is the first time I've seen it in the UK Electrical Forum area at ElectriciansForums.net
100% agree here. The likely explanations (poor hardware) is not the responsibility of either the landlord or tenant, as poor quality but legally...
First time doing a patio Hi guys, had some great advice here before so thought I would ask here for advice again regarding porcelain patio...
Sean-tries-to-tile
