I lumos light switch | on ElectriciansForums
Discuss I lumos light switch in the Talk Electrician area at ElectriciansForums.net
Tumber92
Hi,
I have installed a new I lumos smart light switch it's a 4 gang switch. The switch has 2 modules that control 2 lights each. When my LED downlights are in the the same module as any other light it causes the other light to flicker. Does anyone know why my LED downlights are causing the other lights to flicker I have tried my dining light with LED bulbs and when my downlights were on my dining light would flicker. I swapped my dining light with my under cabinet light and it stopped the flickering on my dining light and started flickering with my cabinet light. All lights are on same lighting circuit. Only difference is the smart module. I know LED lights can cause issues with frequency. When I turn the downlights off it stops the flickering.
[ElectriciansForums.net] I lumos light switch
TL;DR
LED downlights in a smart light switch causing other lights to flicker
Reply to I lumos light switch in the Talk Electrician area at ElectriciansForums.net
Assuming the electrician checked the new driver was capable of supplying current (in other words it provided an output voltage and curent when...
I have three 6" LED wafers and a ceiling fan on the same circuit/switch. I wanted to control them separately, so I installed GOVEE smart lights...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
The lights are on a circuit with other lights, which is a different circuit from this receptacle. Both of these circuits and others are on the...
