I need Advice From the vetrans | on ElectriciansForums
Discuss I need Advice From the vetrans in the Australia area at ElectriciansForums.net
T
TheAprentice
what is the best way to cut tray? without the teeth gettin caught and looking like a novice!
i need advice from the pros!
cheers
first of all, make sure you have the correct type of blade. Blades are lablled with a TPI figure. that means teeth per inch.
18TPI is for cutting thick materials, ie unistrut, angle iron scaffold tube ect.
24TPI is for cuttinmg slightly thinner materials, ie very heavy duty tray, can also be used for unsitrut, conduit, large trunking.
32TPI is for thin materials, ie most grades of tray, trunking, sheet metals.
for very flimsy materials, a junior hacksaw should be used.
Next, majke sure that the teeth point forwards, and the blade is tight.
Nest, ensure that your cutting at about 45degrees to the material, not straight across it, as your teeth will get stuck.
dont force the hacksaw, just let the blade do the work. Also, use the full length of the blade, this will mean you cut it quicker, and more efficiently.
Mark the line to cut using a ruler or straight edge. Let the saw do the work.
If you want to get it done quickly consider using some kind of powered saw such as a chopsaw, angle grinder or cengar, but be sure not to cut any of your fingers off as you might need them later on.
second glasgow biker. a hacksaw with a 32tpi blade, cuts only on the forward stroke. most young-uns rag the saw back and forth like they were pulling their plonker.
i always use a grinder, and its the quickest and neatest way to cut tray. id happily challenge anybody to a race to fab a bend, and i reckon id beat them and do it as neat if not neater.
I do however concede the point about hot works ect, and thats why i mentioned mastering the hacksaw.
The best hacksaw by a mile is the Bacho 319. cant beat it.
Reply to I need Advice From the vetrans in the Australia area at ElectriciansForums.net
E
Mixer Tap Cartridge change advise. Hi Our kitchen mixer tap is leaking around the bottom. Unsure where the leak is coming from but suspect/hope a...
Eejay
E
Help needed for wetroom plan Hi, Can anyone please give me some advice. I have an old bathroom and I want to turn it into a part wetroom. It is...
schoon
