i need help in electrical design L3 assimgnment | on ElectriciansForums
Discuss i need help in electrical design L3 assimgnment in the Commercial Electrical Advice area at ElectriciansForums.net
alx
london
I’ve recently started my level 3 course and I’m doing electrical system designs the one with the hotel extension and pool and café block but I stuck on all of question some guidance would be appreciated thanks
It maybe worth your while contacting a moderator to join the trainee part of the forum.
What are you stuck on exactly? The more detail you can give us, along with your ideas will help massively in the responses you receive.
We will give guidance, but nobody on here will do the work for you.
I stuck on question 2 if you have some guide will be helpful,thanks
We won't answer the question for you but there's some good pointers on the other thread as Archy has mentioned.
[ElectriciansForums.net] i need help in electrical design L3 assimgnment
Reply to i need help in electrical design L3 assimgnment in the Commercial Electrical Advice area at ElectriciansForums.net
If you are using Zdb you do not add on Ze as that is already incorporated into Zdb.
Hi I need help and advice on knowing minimum cross sectional area CSA TN earthing conductor size please
