I need some advice on wiring automatic truck bed lights | on ElectriciansForums
Discuss I need some advice on wiring automatic truck bed lights in the Auto Electrician Forum area at ElectriciansForums.net
Dinsky
Va
Hello... I have very little experience with electrical wiring. I am wanting to install some led strips underneath my bedcover that turn on when the tailgate is open. I also want to be able to override that just in case I need to open the tailgate while driving or something else. I know some people use a pin switch, but I rather not have to drill into my frame. I am wanting to use a magnetic or reed switch but I’m not sure exactly if it will work. I will attach the diagram I plan to follow expect using a magnetic switch instead of the pin switch. Will this work? I would want a NC magnetic switch, right?Also, can I use a magnetic switch on the frame of my truck? Or will that interfere? If so, can I put some plastic underneath or is there another way to make that work?
thanks much!
  • [ElectriciansForums.net] I need some advice on wiring automatic truck bed lights
Reply to I need some advice on wiring automatic truck bed lights in the Auto Electrician Forum area at ElectriciansForums.net
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
Thank you so much for your help with this light work perfect now thank you again much appreciated
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
