Discuss I need to do a sketch/ sketches to show how to remedy a situation.. in the UK Electrical Forum area at ElectriciansForums.net
thanks for the reply. i am assuming it is metal.Is the water supply into the property in plastic or metal?
yes, and i still need assistance.You have asked this before.
How would you fix water pipe in bathroom repaired at previous time using plastic connector? | on ElectriciansForums
Find How would you fix water pipe in bathroom repaired at previous time using plastic connector? Advice and Help. How-to How would you fix water pipe in bathroom repaired at previous time using plastic connector? in the UK Electrical Forum advice boards on ElectriciansForums.net | Free...www.electriciansforums.net
i am a complete novice in this area, so i do need to be spoon fed.So you now need a sketch to demonstrate what you learnt from the other thread?
i dont mean to be rude but if i knew the answer i wouldnt ask it again. i appreciate people replying on here as you dont have to give me your time but please dont make me feel bad for not knowing. im only trying to learn.So you learnt nothing from the other thread?
thank you ill have a readThis may help or confuse the issue: https://www.voltimum.co.uk/sites/ww...t_file/gb/flipbooks/others/0/201207138449.pdf
you have discovered a water pipe in a bathroom that has been repaired at some previous time using a plastic connector. please help, thank you.
Reply to I need to do a sketch/ sketches to show how to remedy a situation.. in the UK Electrical Forum area at ElectriciansForums.net
