M
Mr Curnow
In the end I wasn't even aloud to power my installation. The earthing terminal was somehow disconnected even though I didn't disconnect it. I also had to have extended time plus I was reading the location of the installations wrong. I thought that I had to choose installation location 4 because it was bay 4, well I was wrong with that. It's only about 50mm out though so I don't know if they will be bothered. The neutral was from the isolator was in the wrong position.
But I proved continuity of cpc, polarity and the insulation resistance was >1000M ohm.
I also completed the book that we were given.
How were we supposed to know how the double pole isolator worked if we hadn't learnt it before.
All I can say is I'm much better at theory than practical, it's not like you can go home and wire up a house. There should be more practical experience in these courses.
I probably did fail didn't I, even the teacher told me that I probably failed.
That's just down to more practice. There is a definate nack and order of doing things when doing CU/DBs and getting them to look neat.
Get yourself a bit of plywood and attach a few accessories to it (surface mount boxes where needed) and just practice (a bit artificial, but at least you'll get to know how much cable to trim back for each type of accessory etc.
I didn't think of that, I should buy some accessories.
Upvote 0
I think I've failed the 2330 practical exam.
Electrician Courses : Electrical Quals
Mr Curnow,
Mr Curnow,
Electrical Courses
