series530
We are seriously looking at installing a PV system. Our house faces roughly south west and, at the start seemed to be pretty shade free. We've had two surveys done and both have highlighted shading due to the property next door and a large chimney on the front of our property. This is perfectly fine and understood.
The first company has said that it should be possible to get a system of about 4Kwp using 16 panels arranged as a row of 8 along the ridge and a second row of 8 under the dormers at the front. Both are in the centre of the roof line and avoid the chimney and the shade from next door. This system will use a string inverter (SMA).
The second company has said that the maximum recommendation is about 2Kwp and that only the section just below the ridge should be used because the panels under the dormer would be too close to the bottom of the roof line and may be shaded by a telephone and power line that runs diagonally across the front garden (nearest point to the house is about 10 feet, furthest point is about 45 feet). This company also recommends micro inverters as the chimney may have some effect as a shader.
I have a quote from the first company and it is competitive. The quote from the second company will take some time because they want to do some software modelling to decide the best way. No doubt the second quote will be more for, theoretically, less power output. Obviously, the first company could be suggesting a system with a huge on paper output that, in reality, is in efficient.
I feel that both companies have valid points. I don't want to cut corners but I also don't want to pay through the nose for something that may be a perfect engineering solution but which doesn't provide a decent pay back.
So, what are the rules or suggestions about the minimum spacing between a panel edge and guttering or the base of a dormer? If there are no rules, are there any guidelines? Also, what about these power lines, will they make the panels that much more inefficient and bring the whole system down if I go for company 1? If I had a tree in the front garden I could understand the concern, but power lines a fair way from the house ... is that really a big deal or not?
Many thanks in advance.
