daniel Napier
Good Day;
I am installing an external portable 4KW, 30A generator to my small mountain cabin. I have accounted for an external generator hook point, external 30A fused disconnect leading to the internal 12-way Square-D power distribution board. An external 4ft copper ground rod provides the ground protection to the entire system. My main Square-D board has its own mains isolation switch between the incoming supply and board distribution breakers. I have been reading up on USA electrical code, and I have to say there is allot conflicting information out there. I am aware each state/city has its own requirements however; the N.E.C sets the national guidelines.
To this end, I would like to follow the N.E.C guide lines for my installation. I am not 100% certain on the power board breaker types required for each of my circuits/applications. To my knowledge there are four main types of a breaker: 1) regular breakers, 2) GFCI breakers, 3) AFCI and 4) GFCI/AFCI combo-breakers.
Below are my main circuits and assumption to the breakers I require:
Daniel
- 5 x outside deck lights, on a: 15AMP AFCI /GFCI combo breaker?
- 4 x external power sockets (each socket is already GFCI protected) on a: 20amp AFCI breaker?
- 4 x internal sockets (not individually GFCI protected) on a: 20Amp AFCI /GFCI combo breaker?
- 4 x internal cabin lights; on a 15Amp AFCI /GFCI combo breaker?
- 1 x internal wall mounted 1500W Electric panel heater; on a 15AMP AFCI /GFCI combo breaker?
- I would very much appreciate it if someone could provide me feedback on my breaker choices to comply with the N.E.C guidelines.
- Based on my written description is there anything else I have missed?
Daniel
