Ib on Remote DB | on ElectriciansForums
Discuss Ib on Remote DB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
daiplayer
When designing a distribution circuit for a two way board ( 6A lighting + 16A socket radial ) .
Would the Ib design current for the supply cable be 6+16 amp ? + diversity ?
you could do it that way, or just estimate the actual load on the 2 circuits added together.
makes sense .
In info on exporting pme ?
Im constantly bombarded with q's and arguments on it.
to my understanding the only time it cant be exported is when there is extr. conductive parts in the garage/shed. then a rod to be placed and a seperate rcd.
if not the shed can be protected by the main boards rcd then pme exported.
Main switch and mcbs in garage board ?
Reply to Ib on Remote DB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
sounds like one of those jobs to swerve and let it be someone else's problem
