DJ80D6
super new to these things. i made a drawing to see if this will work. if so which ice cube relay should i use.
the picture shown is a hoa switch. when in auto position the wires coming out have 24vdc. the irrigation controller when command is sent it comes out as 24vac. can i have the switch make the 2 wires from hoa touch and make contact to turn on a pump basically.
