Ideal 32a inline connectors | on ElectriciansForums
Discuss Ideal 32a inline connectors in the UK Electrical Forum area at ElectriciansForums.net
A
amckay
Been to a job today "can you come and have a look at this please my sockets aren't working".
DIY Dave has been in and extended a ring from a point where the client wanted a socket removing.
New sockets now not working. So I proceed to chase around his bodged plastering. This is what I find.
  • [ElectriciansForums.net] Ideal 32a inline connectors
Yeah its like a wago but made by ideal. I use them myself. I can't believe it, they're rated at 32A and the biggest load connected to the ring was a newly installed electric fire place which is on a plug top.
I think it probably wasn't fitted properly and has just been arcing inside but I'll be sending ideal an email
they spin when on the end of the cables so there a load of carp.
shouldnt be able to twist them around the conductor.
it looks like the internal connection between the two push fit terminals has failed.
lever wago's or crimps are the way to go
I think that's the first one I've come across that's failed. They are pretty solid when you pull the two connected ends but if the connectors spin then they can loosen off
that is the problem, we use pushfit connections all the time on danfoss inverters/pumps and they wont come loose if your wiggle or try to twist cable (same design as legrand switches)
Those Ideal in-line connectors are normally very good and should easily handle rfc loads. What's probably happened, is that he's pushed it into the little testing hole cavity instead of the hole for the cable. You need to look side on when the cables are loaded to see if they aligned and fully pushed- in.
Used loads never had a problem with them what i would be more concerned about is weather there is a break in the ring and all the load has been on the connector ,
also as its been plastered over has it got wet
Likewise, used many times with no problem. Interested to see if Ideal come back with a view.
Reply to Ideal 32a inline connectors in the UK Electrical Forum area at ElectriciansForums.net
Thanks a lot for the quick reply. I already have a good number of the 32A single gang connectors so I'll be using those on each individual wire...
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
