Hi,
Anyone have any ideas on this one. Helping out a friend on a job ( not boiler related ) and had a look at their Boiler which hasn't been working since before Christmas. It displays an F3 fault--fan fault. The fan is running, and after a short time the fault code is displayed.
There are 3 other wires back from the fan ( pcb ) to the main PCB, is this a signal for fan running or is that from the pressure switch as normal?.
I'm not a Boiler engineer, an Electrician; so just looking for some likely causes.
The main PCB has been replaced.
Any thoughts?
Regards.
Any thoughts?
Regards.
