Ideal Standard Dual Flush Cistern Overflow Problem Any help greatly appreciated.
It appears that every time i flush the toilet the cistern fills up then overflows back in to the toilet. This can last for 2 minutes or is continually running. I have replaced the cistern dual valve as it was very loose and parts had broken off it and it wasn't a snug fit.
That said, the situation is the same with the water now still overflowing. It appears to be a problem with the syphon. Do i replace it or is there a quick solution. I'm struggling to see what actual part number it is.
I have attached a video to highlight the issue.
Any help is appreciated.
Ideal Standard Dual Flush Cistern Overflow Problem to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
