Identification Required | on ElectriciansForums
Discuss Identification Required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Swansea
Hi all, hope you can help. What is the black unit under the meter. Is it a sort of earth Leakage device[ElectriciansForums.net] Identification Required
Security block. ..........................................
[automerge]1571161896[/automerge]
Most of them are only rated to 60amps,On 100amp supply I take them out and retail.
Reply to Identification Required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Missing pot from trapped gulley (Brand identification request) Hi Guys, I have a customer who has had building work done and the pot (if that's...
Stigster
An old thread on here contains a hint of a method right at the end, but unfortunately the LTP product linked to (the links are obsolete) doesn't...
