Identify old 3ph DB | on ElectriciansForums
Discuss Identify old 3ph DB in the UK Electrical Forum area at ElectriciansForums.net
S P
Good Morning all
Can anyone confirm what this 3ph DB in the photo is?
I believe it is a Crabtree C50 but looking for some confirmation from more experienced eyes.
Many Thanks
  • [ElectriciansForums.net] Identify old 3ph DB
Welcome to the forum S P :).
Yes looks like one, drop a mcb out and its usually written on the side of it, if your stripping it out keep the mcb's as they are like rocking horse doo doo, they are good as a temp' fix on old installations with faulty breakers while you discuss a more permanent solution.
BS3871's, M4.5 and the ampage is on the end of the switches.
Reply to Identify old 3ph DB in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
The MCBs are branded Noark.
