Identify this socket... | on ElectriciansForums
Discuss Identify this socket... in the UK Electrical Forum area at ElectriciansForums.net
A
Anon84
Hi, I was hoping someone might be able to help me identify this wall socket in my house. Its been bugging me for years and searching online doesn't bring anything up.
Thanks.
[ElectriciansForums.net] Identify this socket...
To me it just looks like a air vent.. but if you could give the whole picture what is around it as well as some means of being able to see how tall it is ..
a few dabs of white and i think yellow paint on it
The whole pattern of slots covers about a 1" x 3/4" area. Its in the centre of a wall mounted plate of the same dimensions as a single 3-pin electrical socket plate. It's mounted 8-10 inches off the floor in the corner of my living room, near the aerial point, on an internal wall.
I'll get a better picture when I get home later and will unscrew it to see whats behind it, if anything. I hadn't considered the possibility of it being a vent with it being so small but you never know.
Looks exactly like very old (1960's) multicore computer interconnect cable terminations to me. The plugs to mate with it used to have a thick (1/4") bakelite base with the prongs embedded init, solder tag terminals on the rear, and plastic boot to cover the soldered and then a steel cover with external strain relief. Great big ugly things and the cable going into them used to be very flexible and soft but looked thick enough to be for a shower supply... it was mainly rubber sheath, screening and inner braid though. Never seen one in a wall plate before - only on the back of equipment cabinets. If you ever visit National Computer Museum at Bletchley Park you will see hundreds of the things on old mainframe machines.
Reply to Identify this socket... in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Yea its exactly that, its a photographed print out, the landlord is 85 😂 he is expecting 2 visits i was just trying to save myself the time, the...
suffolkspark
