Identifying BS88 fuse? | on ElectriciansForums
Discuss Identifying BS88 fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Stormflex
Main fuse carrier says 100A 415V BS88 1967 on it.
Looking in OSG page 57 for short-circuit capacity there is a BS88-2 and BS88-6.
How do I know which I have?
Rich
Thanks - 50kA is my answer then.
Now I've just got to try and figure out some of the cable sizes. Lighting and sockets easy. Think the cooker looks like a 6mm!
If you cant ID the main fuse model, then i would i assume it to be the one with the lowest breaking capacity and record that. As long it is below the PEFC / PSCC measurement its not that important in my mind. As most PEFC/PSCC readings are below 6kA it should be OK. As someone has already said it has been renamed BS1361 in almost all domestic situations, and that is what i always use with the odd exception anyway.
Cheers........Howard
Reply to Identifying BS88 fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
Received guidance from a logical soul on the Kawie Riders forum: Acc Fuse Block Power to BAT LOAD, install new cable from BAT LINE to AUX + (and)...
