Identifying Earthing System | on ElectriciansForums
Guest viewing is limited
Discuss Identifying Earthing System in the UK Electrical Forum area at ElectriciansForums.net
catdog
Maybe an obvious one for some.... but would i be right in thinking this is TNCS??
Thanks guys.
[ElectriciansForums.net] Identifying Earthing System
I would agree, despite the initial appearance, it would likely be TNS.
However the arrangement seems odd, it would appear to be a split concentric cable, which would mean that this has been installed separately from the incoming supply as a supply cable would not be split concentric unless it is coming direct from a local transformer.
Thanks for advice guys.
Yeah I'm not great on supply side of things for times like this- also never actually worked with split concentric but was assuming that's what it was.
Obvs for a single phase usually quite easy to spot a TNS.
Also the installation is a commercial unit of steel construction-does anyone know the reason the supply authority picks the earthing system for supplies?......or does it just depend on the type of cable lying nearby?.........or even the weather that day....?
The dnos work under ESQCR regs so not to BS7671.
For routine connections a system/network planner will be the person who decides what the network can support with regard to the proposed installation. Above him/her is a network technician. Higher up the ladder is the Protection Specialist who is god-like within the organisation
Reply to Identifying Earthing System in the UK Electrical Forum area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Recommended Sponsor News
Hi everyone,
