Identifying fused switch? | on ElectriciansForums
Discuss Identifying fused switch? in the UK Electrical Forum area at ElectriciansForums.net
Wales
Hi,
I have recently bought a house and I have a fused switch in my living room which I don't know what it's for.
I believe it was a switch for a electric fireplace that has been removed but the switch was left there.
How can I check and could I possibly change it to a single plug socket instead?
[ElectriciansForums.net] Identifying fused switch?
It looks like what was connected from it has now been removed, the old cpc for the connected cord is still there. The likelihood it can be changed for a socket is probably yes but it would require additional RCD protection if not already in place.
As WW says , a socket will requite RCD protection ( you might already have this ) and a bit of other basic testing like earth continuity. literally a 10 minute job for a sparks
Thanks for the replies.
I was going to attempt to do it myself but am I better off calling a sparky to be safe?
If your CU (consumer unit = fuse box) already has RCD protection and you have some degree of technical skill it is an easy DIY job. If not, then get a sparky in to add RCD protection, etc.
If you are doing it yourself then please get at least a basic socket tester to verify all is well after installation. Something like this is better as it checks if the earth is good as well as providing an RCD test button to verify a fault would trip it:
After you do this socket, take some time to go round the rest of your sockets with the tester just in case...
Reply to Identifying fused switch? in the UK Electrical Forum area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
