Identifying the cables (circuits) on the CU. | on ElectriciansForums
Discuss Identifying the cables (circuits) on the CU. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Goody
London
Hi, what would you guys use to identify the cable to pair them with the circuits on the CU? Could sticky colour tapes be used? Thanks.
If you're just talking domestic it's normally fairly easy to work out. You'll typically have two or three sets of pairs for RFCs. The others cooker/shower (fairly obv due to size). Lighting/smokes again easy to work out. Immersion left over.
If you use coloured tape then don't leave them in the CU (just my opinion, others may disagree).
If you are doing a rewire then it's common practice to identify cables by knicking the outer sheath of cable with a number of notches where there may be some ambiguity involved. These are easily removed when finally terminating the cables.
On Industrial CU's we use Hellermann Tyson Cable markers. Tape or the ones you write on will last about 2 months before they fall off or the ident becomes illegible.
I got two packs - red (0.5-1.5) for the 1.5mm and blue(1.5-2.5) for the 2.5mm - this one too loose for the smaller dia cable. Haven't tried on 1.0mm yet.
I think they look neater - and can be re-used. Fair warning - you will drop a few of the little blighters!
[ElectriciansForums.net] Identifying the cables (circuits) on the CU.
these are ok untill you have a few disconnected then they tend to slip off if its just for marking during a CU change then Scotch 3 m reel of sticky there are cheaper options BUT they dont stick as well
Reply to Identifying the cables (circuits) on the CU. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ok I’ll try this when I’m down
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
