N
nickblake
5ft light fitting opened the box , removed end caps ,removed diffuser , removed center contol gear tray found instructions and it read !!
Firstly unpack your light fitting ....... Mmmm instructions are in the fitting how can i do that
second remove end caps ...........Mmmmm instructions are in the fitting so how can i read that
Remove diffuser .............Mmmm instructions are in the fitting how can i read that
third remove center mounting gear tray ....ah instruction put it all back together put back in box seal and start again by reading the instructions now firstly unpack the fitting...........lol
good thinking guys give instructions to remove packaging and disassembly when the instructions are in the fitting plonkers i ask you i did laugh mind
