IEC 61439-1 - Relationship between prospective fault current and diameter of copper wire | on ElectriciansForums
Discuss IEC 61439-1 - Relationship between prospective fault current and diameter of copper wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Bristol
Hi,
I am currently reading through the standard IEC 61439-1 - Low-voltage swtichgear and controlgear assemblies - Part 1: General rules, and on Table 14 it is stated the "Relationship between prospective fault current and diameter of copper wire" (see picture attached).
I don't understand why the references of the copper wire diameter are so low. Based on this values you will have a very low cross sectional area of the wire. How come for example a 0,8 mm diameter copper wire can withstand 1500 amps ?
TL;DR
Standard 61439-1
  • [ElectriciansForums.net] IEC 61439-1 - Relationship between prospective fault current and diameter of copper wire
I dont think it can withstand that current, thats when it melts .
When we use cable we use a maximum temp of 70 C in the uk for standard installation
yup and that is at the conductor not insulation
Reply to IEC 61439-1 - Relationship between prospective fault current and diameter of copper wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
