IET GN3 is it a book of jokes? | on ElectriciansForums
Discuss IET GN3 is it a book of jokes? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
trebor
I have just read the suggested codes for the new EICR, are they really serious that an installation with no earth is a C2 or am I missing something, ok it may not be dangerous until a fault occurs but surely this could be a fire or even electrocution, a bit late then to do something about it
The C2 will still result in the same conclusion on review of the periodic inspection.
I always try to interpret the coding similar to basic and fault protection, in other words the direct risk or single fault condition.
If there is an exposed live part then it would class as a C1
If the danger requires a single action, such as a fault in this case, or the removal of an enclosure etc then it would be a C2.
As I say, the result is the same.
Reply to IET GN3 is it a book of jokes? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Depending on the size of the company, ie, has a H&S department or H&S. I'd just use the phrase that's it's not compliant with BS standards and...
10K
As a side note I watched a long vid on codebreakers (the people part of making it) and their justification very much related to domestic rented...
Or, in the standard print dialog, just choose the "Open in Preview" (IIRC), then save it from there. It's now a PDF, so compact and prints at hugh...
    • Winner
    • Thanks
14K
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
This sort of thing: https://www.toolstation.com/tis-voltage-tester/p11032 Also remember to test your tester on a known voltage source first...
