C
cairns
Just wondering if I would get a shock if I touch the neutral at a switch point, if the live isn't connected to the neutral?
Discuss If I touch the neutral wire, will I get a shock? in the Australia area at ElectriciansForums.net
Dumbstruck!!
If I am doing major works on a circuit, I will completly disconnect that circuit from the board. I will still test at every point I am working off.(back feed, borrowed from other circuits, the list is endless ) It is also extremly rare for me to work with power on at all. Long time dead mate. Not a clear explanation here but hope it helps a bit.
Reply to If I touch the neutral wire, will I get a shock? in the Australia area at ElectriciansForums.net
