If I was unluckly enough to live in Nottingan, I'd go here.. | on ElectriciansForums
Discuss If I was unluckly enough to live in Nottingan, I'd go here.. in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Along with The Salutation, Royal Children, The Bell, The Peacock, Fellows Morton and Clayton and many more.
The down side is you may run in to me, I’m not barred from any of these.
Reply to If I was unluckly enough to live in Nottingan, I'd go here.. in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
As you've found out, there's capacitive coupling between cores which will induce a voltage into other cores when one (or more) is fed with AC. How...
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
