Hi there.
I’m trying to put a new ceiling light in that’s from IKEA but it has a blue wire and a white wire. How do I know which is live and which is neutral please?
Also can I check that I am going to do this correctly. The current ceiling rose has like maybe 6 wires all connected to a black plastic bit (technical talk ?) and the light wire has 1 brown wire and 1 blue wire that are are screwed into that. My plan is to disconnect the blue and brown wires and replace them with these wires on my IKEA light, live into where the brown was and neutral into where I remove the blue wire from. Is that correct?
Just need to know which is which out of these white and blue wires on the IKEA light are which.
What will happen if I do them the wrong way? Will it just not work or is it very dangerous?
Thank you so much for your help.
