At a job this week I had been and looked at the week before, a handfull of faults mostly lighting," can you change those two lights fittings as well ?" quick look in the box and "yes no problem " I said, what a odd fitting not UK standard at all you either use a cup hook or a cable tie type thing through the ceiling mount after scewing a holder to the ceiling not difficult just odd, with the usual Ikea hyroglyphic instruction leaflet, just a heads up guys and all is not as it seems at first look
Pict
Pict
