ILLUSION FIRES - advice needed | on ElectriciansForums
Discuss ILLUSION FIRES - advice needed in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
andrew kennedy
I have a wood burner (with a glass front) and would like to install an electric illusion 'fire' in the interiar - can anyone suggest where I could but such an item. Andrew
just paint flames on the glass. illusion fire? that's like " i've got a pint of good ale, how to make it look like ale when the glass is empty?"
Is it on of those with a electric fan heater with fake logs and fake flames?
I had a call the other day to fix one of these - opened it up and because it got so hot (left on for several hours) the circuit board had started melting - ÂŁ300 for a new board - cheaper to buy a new one!
carry on drinmking ale, until you think the glass is full when it is empty. at about the same time, stop drinking, and sit patiently near the toilet and wait for the inevitable exit of bodilly fluids. This could be from any of three holes. Caution should be exercised.
Reply to ILLUSION FIRES - advice needed in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
