I'm not an electrician Socket Test reads NEUTRAL FAULT in some of my sockets at home. | on ElectriciansForums
Discuss I'm not an electrician Socket Test reads NEUTRAL FAULT in some of my sockets at home. in the Australia area at ElectriciansForums.net
SteveSloth
Please help with some advice... new to this forum!
I have a 3 bed semi, upstairs in Bed 2 are a double and 2 single plug sockets. Bed 3 has a double and a single socket. The double socket in each of these neighbouring rooms stopped working, along with a single socket in Bed2. I removed the front of the socket after switching off the power, the double sockets all have only 3 wires, the single has 6 wires. I have been told this means that the single is on the ring and the doubles are spurs. I was told roughly what that means! I checked the wires were attached, all seemed fine. A mate leant me a 'socket and see' socket test gadget which shows a NEUTRAL FAULT in each of the faulty sockets. Can this be interpreted by anyone?
I can't get hold of the guy that leant the gadget tonight!
What do I need to do to the sockets to make them work again?
Re: I'm not an electrician Socket Test reads NEUTRAL FAULT in some of my sockets at h
Ill be honest with you and dont mean to be blunt but i would recommend that you get a qualified regestered electrician out to check it , he'll soon find the fault , fault finding is not as easy as you may think and advice that can be given on here will be limited
Beat me too it.
If they were working prior to the fault,you've got a ghost that swaps wire over.
Have you checked what colour cable goes were,i.e blue or black in terminal marked N and brown or red in terminal marked L and green/yellow in terminal marked E.
Side note have you messed with them and now they don't work!
thanks nickblake. I should have guessed that would be the case really, but I suppose a small part of me hoped I could sort it myself quickly and, more importantly, cheaply! Thanks for taking the time anyhow to read my question.:yesnod:
glennspark, the single and double are back to back, so to speak. The sockets are probably original 60's wiring, I have lived here for 8 years and this is the first time I have taken the fronts off the sockets, after they failed to work. I have not removed/swapped any wires, there were none loose that needed any re-attaching and I never actually disconnected the front plate from the wires, just checked they were attached at the back, which they are. Cheers guys.
"sortin em out quickly and cheaply" is one thing mate but if you dont understand about polarity and safe working around electricity etc then its time to pick up the phone methinks.....cant put a price on your life mate.....safety first and a "socket and see" isn`t enough here mate...needs a MFT or seperates ..whatever and someone who knows how to interpret test results.....
What you could have is a ring main which i will say you can then have one spur from each socket unless its fused , you may well find that there are a number of sockets spured off the same spure so socket off a spure then off another spure etc this could be a potential hazard , you could also have a ring fault where you have multiple faults IE 2 open circuits on the same leg which has now blown due to over load , there are so many differant reasons why the fault has occoured hence the advice on getting an electrician so easy to make a mistake , there could be faul fault which could potentially cause a fire , i dont mean to be blunt but its possible
Are these definately on the ring and spurred? A seperate radial for these three perhaps?...If so then maybe something at the board?
yep well that was my thinking when asking about double sockets "back to back"....
I removed the front of the socket after switching off the power, the double sockets all have only 3 wires, the single has 6 wires. I have been told this means that the single is on the ring and the doubles are spurs. I was told roughly what that means! QUOTE]
sounds like you got a junction box hidden somewhere :thinking:
Guys, I am now looking up a local electrician. Safety first! Not caused a fire since they failed about a week ago, but I can't tempt fate.:frown2:
Reply to I'm not an electrician Socket Test reads NEUTRAL FAULT in some of my sockets at home. in the Australia area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
