Hello. Im replacing the original run capacitor in my RV's ac unit. The label says 45uf + - 10%, 7.5mfd / 370vac, 3.4 amp. The one I have to replace it is all the same except it says 30uf + - 5% and its a bit smaller. Will this work?
Discuss Im replacing the original run capacitor in my RV's ac unit. in the The Welcome Forum area at ElectriciansForums.net
Thanks. You wouldn't believe how difficult is to just find a yes or no answer to this simple question.Short answer is no, replace it like for like or spend a lot of money replacing a burnt out motor.
Reply to Im replacing the original run capacitor in my RV's ac unit. in the The Welcome Forum area at ElectriciansForums.net
