Immersion Heater in 1.5mm flex | on ElectriciansForums
Discuss Immersion Heater in 1.5mm flex in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
tomodo
United Kingdom
Hi guys rewiring an immersion heater from a double pole 20amp switch, circuit is wired in 2.5mm t+e up to DP switch. What are peoples thoughts on using 1.5mm flex the regs state that this is capable of carrying u to 16 amps ,would prefer to use 2.5mm flex but can not find a 20amp dp switch with a flex outlet to take a 2.5mm flex ...
circuit is on 16amp breaker and flex run is about 1 metre.
Yep the butyl 1.5mm is the best choice as has been stated, it has a greater heat tolerance and won't break down at the Imm' heater terminals due to the heat.
Reply to Immersion Heater in 1.5mm flex in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
