J
jimjim2991
Hi,
I've made a water recirculation system. To heat the water, I am using:
1kW 11" Immersion Heater
7" 88 Degree High Temp Stat
I'm using 10L of water total, and would like to achieve a stable temperature of 70 Degrees. I was told this would easily be possible (and higher) using what I've listed. However, I'm only managing to achieve, at best, 67 Degrees. The stat is on the highest setting, but still no joy!
Does anyone have any idea why this is not working?
EDIT: It does KIND OF reach 70C, but it's very uncertain about staying there, dropping down to mid-sixties often.
