E
egginyourface
Ive been called out to about 7 different jobs this week!! All to check why newly fitted immersion heaters were not working properly.
Its always the same thing. Plumber fittied new immersion heater and since then the water doesnt get fully hot or after the 1st bath the water wont heat up enough till the next day.
Every single one i go to i find that the plumber has turned thermostat up to the max trying to fix the problem causing cut out to kick in!
My job is as always to check the wiring is done correctly and no loose connections. I never touch the thermostat.:6:
What causes this luke warm problem??
Is it a mistake made by plumber, wrong sized immersion, wrong type etc??
Somebody please tell me as i would like to understand this
