B
Badvocthebad
Hi there, newbie here so apologies if I'm posting in the wrong forum.
We've just moved in to a rental flat which is on an economy 10 meter. Off peak hours are 12-5am 1-4pm and 8-10pm. Obviously to avoid having to get up and switch the immersion off at 5 so I've got hot water for a bath in the morning, I'd like it to work on the timer that is on the system. This is where I seem to have a problem. There is a switch which is wired to the timer and then the immersion element. When the switch is on the timer works but the element is heating water too, whatever I seem to set the timer to do. When the switch is off so is the element, but the timer doesn't tick round either. There is another switch which has always been on since we moved in, which doesn't seem to affect anything at all, at least anything visible or audible. Am I missing something obvious or do I need to get the landlord to get someone to have a look at it. The timer is an old Greenbrook one and from what I can tell of their instructions for their more recent but similar style of timer, you set it so the little pegs are pulled out from the centre for the period that you want it to be on, which seems to go counter to what I've experienced with timers on appliances or plug in ones for example.
Once again, apologies if this is the wrong place, but I'm a bit stumped
Cheers
BDVB
Cheers
BDVB
