J.C.E
"oh my HW is not working"
Either 3 things, voltage not going through stat, through thermal cut out switch, or its not pulling any amps and change the whole lot. But recently I have been having to reset LOADS of thermal cutouts. I know they trip because it gets too hot. My question is, why do they get hot enough to trip?
I have seen this problem very often. If they have another source of heat heating the cylinder, the water gets hotter then the stat is set to. I live in the country and use a back boiler to feed my cylinder in the winter, if the immersion switch is left on, the thermal stat will trip.
Have had this where a Im heater has had the stat changed with one that has a resetable trip on it, continus tripping, all IR tests ok... Found to be that the tank was so old that the bottom Heater was not sitting in water but a pile of old scale 5 inches deap...Plumbers miss this even if they just change the element, as they are not expecting to see so much scale.
J.C.E
Earth
Immersion thermal cutout
J.C.E,
Edd,
