sparkatus12
Hi all had a call out the other day to an immersion heater timer that was apparently glowing red. When I got there I found that the thermal overload had burnt a hole through the side of the timer. The problem is is that this is the second timer that has melted in the last twelve months. (It is a well known timer.) The immersion was pulling 12.2 amps and there are no signs of heat damage to any cables and nothing tripped. Has anybody had this before as understandably the customer wants to know why it has happened twice. Bad luck or underlying problem?.
