I am being asked to quote for some solar pv, solar thermal and gshp on a listed building. The solar pv will be a TIC of 10kW. There is no requirement for baths/showers, just hot water for a kitchen. Although I will of course quote and probably fit whatever they want, with the advent of Immersun and the like I am inclined to suggest that they should save their money rather than install solar thermal, install a couple of extra pv panels instead in the space and just use electricity to heat the water. It will save the visual intrusion of solar thermal pipes on the external of the listed building or cutting through the historic fabric on the internal of the building. Even x3 immersuns for a 3 phase setup will be cheaper and simpler than a solar thermal system. Anyone else been through a similar thought process?
