Imperial cooker cable | on ElectriciansForums
Discuss Imperial cooker cable in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
diditrain
north west
Hi all i am planning on using a consumer unit change in my own home for an assessment and am a little unsure on the following:
My cooker cable is 7/0.44 for the live and 7/0.36 for the cpc. Does anyone have the current carrying capacity for this cable?
Also is this the correct formula to find the metric csa equivelant?
The diameter of one strand in mm squared x pie / 4 and then multiplyed by the number of cores
Many thank`s
49A on an MCB or fuse, 37A on a 3036. (from 14th edition ratings tables).
It's 6.9mm csa conductors with 4.6mm cpc.
AFAIK this is not in the OSG
imperial was always better. don't know why we ever adopted the stupid metric system except to make it easy for morons who can only multiply and divide by 10.
Actually i have nothing against going metric, the only thing i don't particually like is the solid conductors of the smaller sizes of final circuit wiring. Makes pulling singles into conduit and the like a nightmare at times, they just ain't flexible enough, and are too prone to kinking etc...
But it does make me laugh at times, when the younger sparks amongst us think that the old imperial cable sizes are somehow inferior to metric sizes. When in reality most have larger current carrying capabilities than there so-called metric equivalents...lol!!!
and 7/029 didn't used to snap off at the terminations. either. another good reeason fot 4mm radials -- stranded.
Actually in the Far east, they use a stranded 3mm cable, for socket outlets and general small power circuits etc... wouldn't be a bad idea in my opinion, to adopt that size and type of cable/wires in UK and Europe.
Reply to Imperial cooker cable in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
