B
BES
help pls people
cu change. house built in 1968 all old imperial t&e. retired couple so cant afford a rewire. mem bs3036 board. ive not come across this old cable before and not quite sure how to proceed.maybe for assesment with elescsa or building control route (long story very boring).
1.does ths cable comply wth the regs for rating and vd
2.would you i&t and if all ok change board and make note on eic
3.cables need to be extended(adaptable box din rail and wago connector) i presume it is ok to extend imperial cable witn metrc as long as it is noted on eic.
4.do you think assessor or build control will be happy with cu without rewire.
5. what do you puy on eic for cable and cpc csa size.
thanks for your time
any help will be great
thanks neil
thanks neil
