All they need to do now is design a 3 way one and a small maintenance free box for it, then you can use them when people drill through a cable and the cable can't be replaced.
I found a kitchen recently that had lots of these:
The containment for them was expanding foam filler.
Tel likes those. Probably not with the foam though!
I think that was the Wago connector that was Chinese copied... before Wago even made it ! Looks like Wago have now decided to make em...
I think they are still the unbranded ones. Not Wago.
I've used them - they are fine.
Yep, still not aware of an official Wago version.
I've never quite understood the 4mm in brackets. Is that if you have iron-bru and push very hard?!
I have seen that with DIN terminals where the larger size is single solid core, and the smaller the stranded size. Odd, as I would have expected it the other way round!
Presumably no data sheet for those?
I find that careful use of a hammer against some sort of anvil (like a lump hammer)... can make a solid round cable almost square, to better fit the hole in a push connector.
I noticed on CEF website that carriers are available to hold up to five of them side by side. I guess you have to supply your own enclosure 🤔
I think you can get a larger solid core in there because the fine strands will catch and fray on the edges of the terminal if you try and shove one in.
The lever type that is shown above are designed for stranded cable.
Could always put a ferrule on the stranded cable if not a lever type.
Wago 221 suitable for 0.2 - 2.5mm2 stranded and 0.2 - 4.0mm solid.
Chances are, as previously suggested, that's why Ideal have 4mm in parenthesis.
There was a recent discussion sparked by @camoelectric/@Electrics/@biddlybwah that raised the subject of ferruled fine stranded conductors in spring clamp connectors. I think it was @Lucien Nunes who provided sound reasoning why this was less than ideal.
I should clarify. Yes. they're designed for stranded cable, but if you try to shove too large a stranded cable in, the edges will catch and fray. Putting a ferrule on solves that problem but also increases the CSA by the amount of metal in the ferrule, hence smaller rated sizes for stranded vs solid.
pc1966
Dundee
United Kingdom
Electrical Enthusiast (Unqualified Hobbyist etc)
in-line Wago connector
Electrical Tools and Products
pc1966,
Mike Johnson,
