In-roof system on slate tiles | on ElectriciansForums
Discuss In-roof system on slate tiles in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
SolarCity
I've got a potential customer who wants an in-roof system on slate tiles. Has anyone found a good system for this which integrates neatly?
Have a look at GSE integration. Slates sit on the flashings far better than with Easyroof. the panels also sit lower in relation to the slates. There is some fettling/dressing of slate required at the top corners going from vertical to horizontal. I wouldn't bother with the optional top flashing.
Reply to In-roof system on slate tiles in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm looking for advise on the type of mounting system suitable for these types of tiles. These are sort found on new build houses. They are...
J
Riven Slate: use sand/cement or adhesive - is there a definitive answer Hi - my builders bedded 10-12 mm brazilian riven slate on a sand cement...
Jim Rickards
J
